Subtitles out of sync
  • 1
  • 2
Dalom
Dalom
Wed Dec 14, 2016 3:43 am
Re: Subtitles out of sync
#16 by Dalom
Same for me,informed ProgDVB several weeks ago.
They wanted a clip and from where I can see now they have a clip from a member now.
I have tried on two Androidboxes whit same results.
  • Wed Feb 22, 2017 7:29 am
Labbz0re
Labbz0re
Sat Feb 11, 2017 9:30 pm
#17 by Labbz0re
okey! i also have 2 boxes :P
  • Thu Feb 23, 2017 1:40 pm
Labbz0re
Labbz0re
#18 by Labbz0re
Iptv extreme pro has also perfect sub sync =)
  • Sat Feb 25, 2017 8:23 pm
#19 by Prog
Still wait sample from you.
  • Sun Feb 26, 2017 4:25 am
#20 by Prog
Still no normal sample for test :(
But in any case you can try FFmpeg or MediaCodec mode for best sync.
  • Fri Mar 03, 2017 2:23 pm
Labbz0re
Labbz0re
#21 by Labbz0re
I tried that but same delay anyway.
Im going to buy my fourth android box later today, this time Nvidia shield !! Hope its works better on that :)
I can record sample for you then if its not working :)
  • Sun Mar 05, 2017 10:31 am
kroken
kroken
Wed Feb 15, 2017 9:38 pm
#22 by kroken
Yeah, still delay on subtitles.
  • Sun Mar 05, 2017 10:49 am
#23 by Prog
What you mean not working? I need sample in TS. sync not important.
  • Sun Mar 05, 2017 10:56 am
Labbz0re
Labbz0re
#24 by Labbz0re
i mean if the subs dont sync on the shield also..
What do you mean with TS? :)
In few hours when i get the shield i record sample for you, with progtv.beta.2.36.1.4.apk with standard settings, okey ?
  • Sun Mar 05, 2017 11:04 am
#25 by Prog
Yes. You can record sample in any settings.
  • Sun Mar 05, 2017 12:20 pm
#26 by Prog
But in current version you can select MediaCodec or FFMpeg for fix problem with sync.
  • Sun Mar 05, 2017 12:21 pm
kroken
kroken
#27 by kroken
Can you fix subsync with openmax??
  • Wed Apr 12, 2017 2:45 pm
  • 1
  • 2
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 4:00 am
