Constant issues with audio jaggines, cutting out and getting out of sync
  • 1
  • 2
  • 3
Re: Constant issues with audio jaggines, cutting out and getting out of sync
#16 by Prog
Users not have problem with syns very many years (after add ProgDemux and Prog audio renderer).
Try again install ProgDVB with default settings.
  • Sat Apr 14, 2018 3:21 pm
avada
avada
Mon Jun 02, 2014 1:44 pm
#17 by avada
I did that before, because of the also persistent hangs when switching channels.
  • Tue Apr 17, 2018 10:12 am
#18 by Prog
Send me logs of this. What audio device you use?
  • Tue Apr 17, 2018 2:03 pm
avada
avada
#19 by avada
"Default directsound device", which is the realtek sound adapter of my mobo. But it was the same case with my old mobo with a xonar soundcard.
(I also tried changing between audio renderers before)
Any instruction on how to create a proper log?
  • Tue Apr 17, 2018 3:19 pm
avada
avada
#20 by avada
Well, I enabled logging, and there was a freeze right now, so here's the log folder:
Logs.7z
(19.67 KiB) Downloaded 616 times
  • Tue Apr 17, 2018 4:19 pm
#21 by Prog
MS demux?
  • Wed Apr 18, 2018 9:51 am
avada
avada
#22 by avada
MS demux?
Hmm? What are you asking/saying?
If you mean have I tried changing demuxers, then the answer is yes. (Also video renderers)
  • Wed Apr 18, 2018 12:06 pm
#23 by Prog
In MS demux sync. not depended from me. My sync function working only if ProgDemux + Prog Audio renderer
  • Thu Apr 19, 2018 8:08 am
avada
avada
#24 by avada
It's still unclear. Yo mean that the hang happened in the MS demuxer?
  • Thu Apr 19, 2018 12:53 pm
avada
avada
#25 by avada
By the way with ProgDemux + Prog Audio I get severe issues. Constant framedrops. Some channels look like a slideshow, unwatchable. (Others are fine)
ProgDemux + Prog Audio is unusable because of this. (Both with madVR and EVR)
  • Thu Apr 19, 2018 1:08 pm
avada
avada
#26 by avada
I just had a hang again. This time with all progDVB demuxer and audio renderer:
Logs.7z
(118.38 KiB) Downloaded 594 times
  • Fri Apr 27, 2018 3:52 pm
avada
avada
#27 by avada
And again...:
Logs.7z
(73.99 KiB) Downloaded 575 times
  • Fri Apr 27, 2018 4:07 pm
avada
avada
#28 by avada
Three times the charm:
Logs.7z
(76.41 KiB) Downloaded 640 times
  • Fri Apr 27, 2018 4:48 pm
avada
avada
#29 by avada
So these issues will never be fixed...
  • Fri May 04, 2018 9:38 am
avada
avada
#30 by avada
This program is hopeless.
I constantly have to change between prog and microsoft/system demuxers and audio renderers. With neither do all channels work. And things never improve. Despite many updates.
  • Thu Jun 21, 2018 1:56 pm
  • 1
  • 2
  • 3
Email sent.
  • It is currently Sun Jul 26, 2026 3:40 am
