    • Unanswered topics
    • Active topics
progdvb crashes when cliked on iptv channel
  • 1
  • 2
keyvan1
keyvan1
Mon Mar 31, 2025 5:02 pm
Re: progdvb crashes when cliked on iptv channel
#16 by keyvan1
Mon Apr 07, 2025 5:28 am
Crash only in x86? Please not remove old x86 version. I must fix this problem.
it works fine in just x86 version.
it crashes in 64 bit
  • Mon Apr 07, 2025 3:54 pm
#17 by Prog
Are you sure? logs of x86 version.
  • Mon Apr 07, 2025 4:02 pm
kaya
kaya
Sat Apr 05, 2025 9:56 pm
#18 by kaya
Hi
This problem continues in all versions released after x86 7.65.04. There is a problem not only with IPTV, but also with all applications within the program. There is no problem in standard and 64 bit versions.
  • Mon Apr 07, 2025 5:23 pm
masheee
masheee
Mon Mar 28, 2022 9:42 pm
#19 by masheee
I reported this same issue some time ago.
  • Thu Apr 10, 2025 9:39 pm
#20 by Prog
I have 3-4 reports about this problem but still no one idea :( Many tests and no one crash on my PC.
Do you have any have more information? Best if "In this mode it crash in this mode it doesn't."
  • Fri Apr 11, 2025 6:14 am
#21 by Prog
Please send me logs from last prerelease https://www.progdvb.com/download_progdv ... lease.html
  • Mon Apr 28, 2025 4:30 am
  • 1
  • 2
Return to “ProgTV Windows”
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 11:20 am
