#17
Prog wrote:Please check settings->Device options.
Must be FireDTV mode.
That setting is correct!
I did some more testing on scan stransponders, and take a look at the screenshots at the bottom. At that transponder i can find the channels, but they are all wrong. Shows as No Name. As you can see on second picture, even the EPG information shows, the audio language etc, but nothting else, and no image. What do you make of this?
#19
Today, the rest of my HD channels are gone. Yesterday it was ok, during night something has changed, and i cant find them on a new search... As far as i can see, all other channels are ok. This is strange. Could it be that the provider has changed some "settings" for the HD broadcasting, or something??? Please help here, this is confusing!
#20
Hi again, did you do any research into this? I'm a little bit dissapointed since all my HD channesl are missing, and i dont say it is a waste, but HD support was kind of the main reason i purchased a lisence for progdvb pro. :cry:
HD channels just dissapared over night, and when i tried to rescan channels i got this result:
The only HD related channel i get now is:
(i dont have a subscription for it, so i dont know what it is.)
At another room in my house, i have also 5E running Viasat channels, but i switched my cables from my satellite, so i could connet 5E to my FireDTV card. I did a channelsearch, and it appears that i get all HD channels from Viasat.
Final case is:
- Conax 1w HD channels did all work fine, in august, i used progdvb pro with 1 month trial.
- about 1 or 2 month after my trial was over, i finally purchased progdvb, because i wanted to watch in HD. Then, only a few HD channel was available.
- A few days ago the rest of my HD channels on 1w is lost.
- I didnt do any changes to compter HW or software. As my pc is online 24/7, i didnt even reboot my pc that night the last HD channels got lost.
- I've also tried to update transponders
- I've also installed the beta drivers for FireDTV dvb-s2 drivers
I've tried to google a lot myselfe, and the closest i got was this:
All known devices are able to detect the modulation (QPSK, 8PSK) automatically, thus ignoring this setting, except Hauppauge and FireDTV DVB-S2 cards in case of DVB-S2 transponders. Additionally they require correct FEC and Pilot Symbols on/off settings in DVB-S2 mode. Roll-Off doesn't seem to have much influence, however.
taken from:
http://www.dvbviewer.com/griga/TransEdi ... Properties
Please, i need help, give me some value for my money :?
