    • Unanswered topics
    • Active topics
e grave shows as c caron in French
  • 1
  • 2
Re: e grave shows as c caron in French
#16 by Prog
I am not know :( May be too short. I can playback it in players but impossible scan in ProgDVB.
  • Fri Nov 15, 2013 11:41 am
JohnyQ
JohnyQ
Thu May 09, 2013 11:18 pm
#17 by JohnyQ
JohnyQ wrote:
Prog wrote:Ops. TS recorder ...
I already sent a TS recording. What was wrong with that?
I sent you a new five minutes recording. You'll receive a separate notification.
The text should read "La confiance règne....pense que son père...."
  • Sun Nov 17, 2013 4:10 pm
#18 by Prog
Hm. Is it bitmap subtiles? ProgDVB receive images (not text) and not working with codepages.
Do you have same with other software?
  • Mon Nov 18, 2013 5:18 pm
JohnyQ
JohnyQ
#19 by JohnyQ
Prog wrote:Hm. Is it bitmap subtiles? ProgDVB receive images (not text) and not working with codepages.
Nope. Used Pouchin TV Mod before and had no problems.
  • Mon Nov 18, 2013 11:52 pm
JohnyQ
JohnyQ
#20 by JohnyQ
This is solved since ProgDVB version 7.03
Thanks so much Prog :-)
  • Tue Mar 25, 2014 1:15 pm
#21 by Prog
Same in last prerelease?
  • Tue Mar 25, 2014 2:42 pm
JohnyQ
JohnyQ
#22 by JohnyQ
Prog wrote:Same in last prerelease?
Yes, characters are still properly displayed in 7.03d.
  • Tue Mar 25, 2014 4:23 pm
  • 1
  • 2
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 10:58 am
