Re: After version 6.93 the audio stopped working
#16
Prog wrote:Yes, this is possible. Can you record me sample of channel? 3-5 minutes.
Ok ...
I'll try to upload later as the file is too big but from what I saw the recording does not work as it should be, that is when I put the video in play, the video stay with frozen image and also does not give any sound ...
Anyway sending a photo of the version 6.93 works and a photo version 6.94.07 does not work
The two versions are with exactly the same settings ...
photos.rar
Photos
(1.25 MiB) Downloaded 406 times
#23
marec wrote:
morfive wrote: In my case only works with AAC / LATM but he always chooses MPG12
Are you using Audio Processor? This last pre-release (95.7b) for me works with AAC audio, but only if Audio Processor is ON.
yes... the Audio Processor it is ON.
But I've tried with all possible combinations and up to there are some settings that work but when I change the channel or when I restart the program stops working again ...
#29
marec wrote:Morfive,
Can you try this:
- pre release 95.7c
- Prog demux
- LAV audio codec in AAC audio codec (enable all types in it)
- no audio processor.
This seems to work all AAC for me.
PS - Sorry, it is "d" pre-release.
Well apparently now works ...
Only one small problem after a few minutes the audio starts getting out of sync ...
but anyway, Thanks ...
