udp://@:1234 - is not mutlicast. Try restream to unicast or to multicast.
ps: I mean log or RTSP dialog of some other software which working with your device.
Re: SAT>IP Protocol support
#17Hi,Prog wrote:udp://@:1234 - is not mutlicast. Try restream to unicast or to multicast.
First SUCCESS!
FFMPEG Command:
$ ffmpeg.exe -i rtsp://192.168.1.212:554/programID=5266433 -copyts -codec copy -f mpegts "udp://224.0.0.1:1234"
Channel list file (m3u):
#EXTM3U
#EXTINF:0,restreaming
udp://@224.0.0.1:1234
Then I can "scan" and one channel found!
After this trials, I'll try to create your logs of RTSP. Have you reviewed the PDF?
Thank you!
#18Hi Prog,
At time, I'm testing this Linux tool: http://www.live555.com/openRTSP/
I feel that you can be inspired by the source code of this tool to add RTSP support to the IPTV module.
Nevertheless, I'll provide soon the LOGs you request about the calls of the procotol between a client and my STB. I found the debug of the VLC the most verbose and useful to create them (without using a network sniffer, like wireshark).
Regards!
Regards!
#19Hi Prog,Prog wrote:udp://@:1234 - is not mutlicast. Try restream to unicast or to multicast.
Your IPTV module supports "unicast"? What is then the correct syntax that your module expects in the m3u file?
Thank you!
#21Yes! But this is for TCP (http) unicast. My question is about UDP UNICAST.Prog wrote:http://127.0.0.1:5000 for example.
#22About log. For example you can use vlc with log keys.
for example
vlc.exe --extraintf=http:logger --verbose=2 --file-logging --logfile=vlc-log.txt
open rtsp://xxx
and send me vlc-log.txt
for example
open rtsp://xxx
#23Hi Prog,
I have do it already (the vlc log). The relevant data:
Client: 192.168.111.102
Sat>IP server: 192.168.111.212
It's good for you?
Opening connection to 192.168.111.212, port 554...
...remote connection opened
Sending request: OPTIONS rtsp://192.168.111.212:554/programID=5266433 RTSP/1.0
CSeq: 2
User-Agent: LibVLC/2.1.3 (LIVE555 Streaming Media v2014.01.21)
Received 115 new bytes of response data.
Received a complete OPTIONS response:
RTSP/1.0 200 OK
CSeq: 2
Date: Thu, May 29 2014 13:43:06 GMT
Public: OPTIONS, DESCRIBE, SETUP, TEARDOWN, PLAY
Sending request: DESCRIBE rtsp://192.168.111.212:554/programID=5266433 RTSP/1.0
CSeq: 3
Accept: application/sdp
Received 378 new bytes of response data.
Received a complete DESCRIBE response:
RTSP/1.0 200 OK
CSeq: 3
Content-Base: rtsp://192.168.111.212/
Content-Type: application/sdp
Content-Length: 222
v=0
o=- 1401370232067000 1 IN IP4 192.168.111.212
s=SatIPServer:1 1
t=0 0
a=control:rtsp://192.168.111.212/programID=5266433
m=video 0 RTP/AVP 33
c=IN IP4 0.0.0.0
Sending request: SETUP rtsp://192.168.111.212/programID=5266433 RTSP/1.0
CSeq: 4
Transport: RTP/AVP;unicast;client_port=53820-53821
Received 220 new bytes of response data.
Received a complete SETUP response:
RTSP/1.0 200 OK
CSeq: 4
Transport: RTP/AVP;unicast;destination=192.168.111.102;source=192.168.111.212;client_port=53820-53821;server_port=6970-6971
Session: 0F5511ED;timeout=60
Sending request: PLAY rtsp://192.168.111.212/programID=5266433 RTSP/1.0
CSeq: 5
Session: 0F5511ED
Range: npt=0.000-
Received 140 new bytes of response data.
Received a complete PLAY response:
RTSP/1.0 200 OK
CSeq: 5
Session: 0F5511ED
RTP-Info: url=rtsp://192.168.111.212/programID=5266433
It's good for you?
#24Hi,
Good news! Using "manual" commands I can view some channels using ProgDVB from my SAT>IP tuner.
In a Linux machine I use openRTSP and socat to send a multicast stream with the Transport Stream filtered for the channel. An example of the command:
openRTSP -v rtsp://192.168.1.212:554/programID=5272581 | socat - udp:224.0.0.1:5000
In the IPTV Module, you can import a m3u file with udp://@224.0.0.1:5000 and execute the scan (parsing SDT).
This isn't a final solution, pure manual commands, but is a good start.
For Prog: If you like to obtain more RTSP logs, the best option is use "openRTSP". It's using the same LIB as VLC, and with identical log outputs. And is more easy to use!
If you need more logs, please contact with me.
#25RTSP is not ease and not quick. I must spend some time for that in future. Your log is good but testing for the device can be demanded. Is it vpn possible?
#26I can provide to you more logs, captures (raw TS from the SAT>IP server), and I can do more tests as you request. VPN isn't available (I don't have a permanent upload link, sorry).Prog wrote:RTSP is not ease and not quick. I must spend some time for that in future. Your log is good but testing for the device can be demanded. Is it vpn possible?
Perhaps you like to buy a device (50 Euros only!): http://www.amazon.de/Smart-Satelliten-R ... 196&sr=1-3
In reference to the RTSP implementation:
- From my point of view, the best solution is an architecture of 2 processes: the "selector" and the "sink". The "sink" process is very similar to an RTP UDP unicast receiver. And the "selector" process is a separate task that asynchronously is generating the calls of the RTSP control protocol. With parallel execution of both tasks and the decoupling of them, the implementation will be more simple.
Regards.
#27Please try rtsp:// links from your device in last ProgDVB prerelese and send me ProgDVB logs (Settings->Options->Debug)
ps: You can send me logs on email
#28I'll do between today and tomorrow. The last "pre-release" vesion is 7.05.3a ? http://www.progdvb.com/download_progdvb_prerelease.htmlProg wrote:Please try rtsp:// links from your device in last ProgDVB prerelese and send me ProgDVB logs (Settings->Options->Debug)
Thank you for your support!
#29I am not sure in this version. You can wait next one ...
btw, what is main parameter for your device? Some m3u list with transponders or this list from upnp or?
#30Prerelease updated. But this is not last version. RTSP quite complex and old protocol...
