Ok, now I uploaded the other files that I believe showed some relevant stuff.Prog wrote:I need all log files after crash. In your case need netclient* files.
#1712Please zip all files from all folders in Logs
#1713ok,done that. btw, thank u for carrying.Prog wrote:Please zip all files from all folders in Logs
#1714When using EVR Custom Presenter the image freezes sometimes (audio plays ok) and I have to restart playback to see video again. I have found out, that it always happens just after some UAC dialog appears (e.g. when starting some other program using "Run as administrator"). It does not happen with Enhanced Video Renderer.
I have Windows 10 Home 64b.
#1715You can use EVR as more simple renderer.
#1716I know, just fixing the problem would be good. The custom renderer was always working better for me (e.g. better seeking, EVR has very often long black screen after seek). Not sure when the freeze problem started, maybe after upgrade to Windows 10.Prog wrote:You can use EVR as more simple renderer.
#1717I've been using ProgDVB without issue for several months, now after a Win10x64 system update the ProgDVB will not start. I have uninstalled and reinstalled and it still does not start. Any idea what problem is please?
#1718same problem here after windows 10 update on Tuesday 14.03.
Hardware: Hauppauge WinTV-Starburst
Windows 10 pro x64
windows 10 error message: progdvb is not compatible.
Windows 10 pro x64
#1719What in logs of Windows? Can you get logs of ProgDVB? Same without UAC?
ps: I am not have this problem.
#1720>What in logs of Windows? Can you get logs of ProgDVB? Same without UAC?
Same problem with or without UAC. I posted a zip of my ProgDVB logs previously. Same with 32bit and 64bit ProgDVB.
#1721This is not logs. Please enable logs before crash.
In ProgDVB.ini
[Debug]
EnableLogs=1
Log2=1
What number of windows 10 update which is a problem source?
In ProgDVB.ini
[Debug]
EnableLogs=1
Log2=1
#1722ExeptionReport:
time: 15.3.2017 16:12:9
Type: Crash in unmanaged part
Module: x64
Thread: 0x27f4
I have looked about progdvb.ini at c:\program files\dvbprog.
There is NO .ini!
Now I checked a system backup file (acronis) from 10th of March. There ARE files named ProgDVB.ini and ProgDVB.ini_copy.
1. There is NO section Debug!
2. I have a Hauppauge WinTV-Starburst PCIe Card installed in 2016. The old .ini file shows at section
Caption={BDA} Pinnacle PCTV 3010iX BDA DVBT Tuner
InstallTimeDevice=pinnacle
IPMS_Options_Transcoding-Pinnacle PCTV 3010iX BDA DVBT Tuner#0
I used the Pinnacle Card very long ago. This card was changed to a Technisat Skystar HD and in the year 2016 to the current Hauppauge.
My next steps today:
deinstall my Anti Virus Program...
I will do a system recovery from 10th of march. Then i will update win10 again and see what happen... step by step.
Module: x64
Thread: 0x27f4
There is NO .ini!
#1723Please send me logs from prerelease. Always enabled in this version.
#1724progdvb do not start after installation of cummulative update windows 10 kb4013429-x64.
look at logs.rar
look at logs.rar
- logs.rar
- (48.2 KiB) Downloaded 563 times
#1725Thanks! Try last prerelease version and send me logs if still crash.
