I got the same Problem
progdvb do not start after installation of cummulative update windows 10 kb4013429-x64.
#1728I try your current version 7.17.9x64 now:
import settings from older version-> crash (attachment logs)
Language: german --> I am not able to change back to default language english
Sat scan (Astra 19.2) works fine.
But when I try to choose any Station (ZDF neo HD for example) there is no video.(attachment)
Maybe there is a problem with the video codecs? (attachment)
- logs_7.17.9x64.rar
- (665.17 KiB) Downloaded 1182 times
#1729Try change video codec and video renderer. What element is reason of crash?
#1730H.264/AVC -> Microsoft DTV-DVD -->attachment
all other renderes crash the program.
#1731attachment
error message: ProgDVB Engine API Except in ProgDvbEngine:Engine_SetChannel
#1732Do you try different video renderers? Send me logs with VMR9
#1733I have just installed 16.03.2017ProgDVB v7.17.9. Fix crash on Windows10 with last updates but this also does not work for me.Prog wrote:This is not logs. Please enable logs before crash.
In ProgDVB.ini
[Debug]
EnableLogs=1
Log2=1
What number of windows 10 update which is a problem source?
Sorry, I hope I now understand logs and attach a new log for the new 7.17.09x64 update (edited for privacy). Unlike previous version this one now starts OK in Win10x64 but after I enter an m3u playlist and the channel list appears, when I click on any channel to start streaming the ProgDVB program aborts, disappears from screen without any warning message.
Can you please advise? Many thanks for feedback.
- Logs.zip
- (7.62 KiB) Downloaded 1210 times
#1734Seems that Microsoft smashed some codec :
"After investigating, this is the filter responsible:
Microsoft DTV-DVD Video Decoder
C:\Windows\SysWOW64\msmpeg2vdec.dll
{212690FB-83E5-4526-8FD7-74478B7939CD}"
People have problems with .ts files and some with mp4 files.
For Win10 deinstalling the latest update KB 4013429 helps.
I use shutup10 for blocking the update to reinstall.
#1735You can rename this file. But why msmpeg2vdec.dll not registered on my PC? Do you have some MS media software?
#1736Yes, i upgraded win 10 from win 8.1, where i had "Windows media center".WMC disappeared with Win10, but the registered codecs not.
#1737I upgraded Win10x64 from Win7. Is there a solution for making latest ProgDVB work or should I just wait for a new release please?
#1739Thanks. That's worked for now.Prog wrote:You can unsinstall KB4013429 also.
#1740Uninstall the KB is no option, I think.
my workaround:
https://github.com/Nevcairiel/LAVFilters/releases
LAVFilters-0.68.1-Installer.exe download and install
start progdvb
settings
video codecs
MPEG-2 –> LAV Video Decoder
H.264/AVC –> LAV Video Decoder –>settings LAV Video Decoder—> Formats—> disable “use Microsoft WMV9 DMO Decoder...”—>OK –> restart progdvb
After that, my progdvb works fine again on 2 machines.
my workaround:
start progdvb
settings
video codecs
