First three transponder of the scan:
146 10.971805000 192.168.1.121 192.168.1.6 TCP 66 50429 > rtsp [SYN] Seq=0 Win=8192 Len=0 MSS=1460 WS=4 SACK_PERM=1
148 10.975846000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=1 Ack=1 Win=65700 Len=0
149 10.975944000 192.168.1.121 192.168.1.6 RTSP 107 OPTIONS rtsp://192.168.1.6:554/ RTSP/1.0
152 10.987698000 192.168.1.121 192.168.1.6 RTSP 239 SETUP rtsp://192.168.1.6:554/?src=1&freq=10714&msys=dvbs&plts=off&fec=&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0 RTSP/1.0
156 11.191612000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=239 Ack=353 Win=65348 Len=0
255 26.007253000 192.168.1.121 192.168.1.6 RTSP 143 PLAY rtsp://192.168.1.6:554/stream=167?delpids=0 RTSP/1.0
258 26.012829000 192.168.1.121 192.168.1.6 RTSP 143 PLAY rtsp://192.168.1.6:554/stream=167?addpids=0 RTSP/1.0
264 26.207193000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=417 Ack=668 Win=65032 Len=0
550 41.017832000 192.168.1.121 192.168.1.6 RTSP 143 PLAY rtsp://192.168.1.6:554/stream=167?delpids=0 RTSP/1.0
552 41.020678000 192.168.1.121 192.168.1.6 RTSP 218 PLAY rtsp://192.168.1.6:554/stream=167?src=1&freq=10729&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=22000&mtype=8psk&pids=0 RTSP/1.0
558 41.247784000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=670 Ack=982 Win=64716 Len=0
571 41.777885000 192.168.1.121 192.168.1.6 RTSP 143 PLAY rtsp://192.168.1.6:554/stream=167?delpids=0 RTSP/1.0
573 41.781664000 192.168.1.121 192.168.1.6 RTSP 221 PLAY rtsp://192.168.1.6:554/stream=167?addpids=1024,1025,1026,1027,1028,1029,1030,1031,1032,1033,1034,1038,1039,1041,1043,1044 RTSP/1.0
580 41.977808000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=926 Ack=1296 Win=64404 Len=0
582 42.005879000 192.168.1.121 192.168.1.6 RTSP 221 PLAY rtsp://192.168.1.6:554/stream=167?delpids=1024,1025,1026,1027,1028,1029,1030,1031,1032,1033,1034,1038,1039,1041,1043,1044 RTSP/1.0
584 42.008935000 192.168.1.121 192.168.1.6 RTSP 148 PLAY rtsp://192.168.1.6:554/stream=167?addpids=17,16 RTSP/1.0
589 42.207819000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=1187 Ack=1611 Win=65700 Len=0
650 43.963937000 192.168.1.121 192.168.1.6 RTSP 148 PLAY rtsp://192.168.1.6:554/stream=167?delpids=17,16 RTSP/1.0
652 43.968107000 192.168.1.121 192.168.1.6 RTSP 218 PLAY rtsp://192.168.1.6:554/stream=167?src=1&freq=10744&msys=dvbs&plts=off&fec=56&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0 RTSP/1.0
659 44.173900000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=1445 Ack=1928 Win=65380 Len=0
667 44.340938000 192.168.1.121 192.168.1.6 RTSP 144 PLAY rtsp://192.168.1.6:554/stream=167?delpids=0 RTSP/1.0
669 44.342121000 192.168.1.121 192.168.1.6 RTSP 172 PLAY rtsp://192.168.1.6:554/stream=167?addpids=100,200,300,400,500,600,17,16 RTSP/1.0
684 44.540905000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=1653 Ack=2246 Win=65064 Len=0
690 44.745969000 192.168.1.121 192.168.1.6 RTSP 172 PLAY rtsp://192.168.1.6:554/stream=167?delpids=100,200,300,400,500,600,17,16 RTSP/1.0
692 44.748966000 192.168.1.121 192.168.1.6 RTSP 145 PLAY rtsp://192.168.1.6:554/stream=167?addpids=16 RTSP/1.0
697 44.955926000 192.168.1.121 192.168.1.6 TCP 54 50429 > rtsp [ACK] Seq=1862 Ack=2564 Win=64744 Len=0
866 52.873289000 192.168.1.121 192.168.1.6 RTSP 145 PLAY rtsp://192.168.1.6:554/stream=167?delpids=16 RTSP/1.0If a transponder is offline or wrong in the list DVBViewer will skip waiting for data after 30 seconds.
Also DVBViewer waits 30s if PAT got read but PMT faild. This waiting time is realy high.
If the transponder is alive the scan take ~2-10s
I don't think that pids=all would be faster because there you have to do the scan also step by step (PAT -> PMT, SDT,...).
And the data is repeated all 100-500ms.
Anyway, if it takes longer than the methode with pids=all I think it should not be a problem because of the working result.
Myself, I do not scan every day the whole satellite.
