Subtitle is there, but not visible
  • 1
  • 2
  • 3
  • 4
diogosena
diogosena
Fri Feb 02, 2018 4:36 pm
Re: Subtitle is there, but not visible
#46 by diogosena
hi, finally got the fc error
hope this is useful now
Android.zip
(7.71 KiB) Downloaded 326 times
  • Tue Feb 20, 2018 12:20 am
#47 by Prog
No ProgTV logs?
  • Tue Feb 20, 2018 7:51 am
diogosena
diogosena
#48 by diogosena
i did take a look in the others and found nothing, I assumed they weren't being helpful.
if it happens again, I send you the whole Progtv folder.
  • Tue Feb 20, 2018 9:44 am
#49 by Prog
Is it logs enabled?
  • Tue Feb 20, 2018 2:25 pm
diogosena
diogosena
#50 by diogosena
yes, verbose option.
  • Tue Feb 20, 2018 4:13 pm
diogosena
diogosena
#51 by diogosena
Hi again, this one is not a force close, its a image freeze (kodi with amcodec has the same problem)
as soon as it happenned, I exited and got the logs ( around 19:52 )
happened again, around 21:07, but now I was trying mediaplayer+ mode.
ProgTVLogs_mediaplayerplus.zip
(782.26 KiB) Downloaded 301 times
ProgTVLogs.zip
(191.07 KiB) Downloaded 285 times
  • Tue Feb 20, 2018 11:06 pm
diogosena
diogosena
#52 by diogosena
another image freeze, around 17:30 (prev1 folder)
ProgTVLogs.zip
(438.59 KiB) Downloaded 288 times
  • Sat Feb 24, 2018 8:42 pm
diogosena
diogosena
#53 by diogosena
18:20 (prev1 folder again)
exited by itself, without showing any error
are those logs being useful? should I keep sending them?
  • Sat Feb 24, 2018 9:25 pm
  • 1
  • 2
  • 3
  • 4
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 2:57 am
