sorry for the late reply, but some testing has been necessary.
Since 70.05 recording is partially ok. Just for the moment im running 70.06
Remenber: at a 64-bit-machine, orderded also but got "only" a 32-bit-Key.
I aplogize to your permanent updates, which are mosten quicker than testing the newest version will need
Why partially ?
ProgDVB-service failed totally, so I'm back to Windows scheduler.
Off course:
I've deinstalled the older versions of ProgDVB reguallary and cleared also the registry-entries you are setting.
No problem so far.
Installed the 70.05 from base new, give again my key (yes, even that file I´ve cleared!) and voila - 70.05 is working perfect as I like ist.
70.06 did the same.
Only use of ProgDVB-service fails
So I leave at that state and avoid your service
