Hi,
Just some thoughts:
1. Some VERY important commands missing in ProgDVB 5x:
NextFolder, PrevFolder, ChangeAudioStream
Just to note how much they are important (at least for ppl like me who sit a bit away from the PC and want to do all the cammands with remote):
Imagine you have 8 favorite folders with 30 channels in each,
now you are in middle of a folder and want to go to some other folder, you'll have to press the Down button and keep it until you reach the desired folder, not bad but just imagine you have the 8 folders open and are in the last channel of the eighth folder, now you want to go to the first channel of the first folder
, you'll have to press Up and skip some 240 channels to get there,
, In the 4x generation however you just press NextFolder and PrevFolder buttons and done. (can life get easier than this realy
For the ChangeAudioStream option too you'll have to restore to window mode and do it with mouse (PITA if you have many multilingual channels that when autoupdate themeselves revert back to the original language.
), I know we can set the language in options but some channels show lang and sub info with numbers and need editing.
Well, just 3 simple commands and that much of time and work saved
2. The teletext in the previous versions did not disapear after the common 5 second OSD timelimit and I would close it with the OK button which was nice beacase now it disapeares and I have to press a button to keep it open, now if I want to realy read something I have to press a button every few seconds to keep the teletext open which is not so nice , Having these in mind I think it's better for EPG and teletext to be closed manualy by pressing OK or some other button of choice as it was in the 4x gen.
also I've set the VoumeUp and Down commands to the Right and Left buttons of the remote (which is the standard for remotes that don't have special volume buttons), so I'm missing the Right and Left Commands that's needed to browse the subpages , i.e: subpage 2,3,... of page 110.
any ideas ?
and 3. Thanks for making the best DVB app and I hope by readding these little features to the program you will make it closer to perfection.
...Sorry that it got too long and waiting for your reply Prog.
