GENIATECH MyGica USB stick DVB-T2 device ( T230 driver )
  • 1
  • 2
  • 3
  • 4
  • 5
User avatar
crazycat
Wed Apr 02, 2008 1:33 am
Contact:
  • ICQ
Re: GENIATECH MyGica USB stick DVB-T2 device ( T230 driver )
#61 by crazycat
Unselect "Use demux/TIF"
  • Sat Dec 10, 2016 6:55 pm
serkanguzel
serkanguzel
Sat Nov 30, 2013 8:09 am
#62 by serkanguzel
crazycat wrote:Unselect "Use demux/TIF"
Okay master,
7.16.9b
7.16.9b - Unselected "Use demux/TIF
Over installing the 7.17.0 version, PC crash/BSOD !
Always crash. So, it is not possible to reach the "demux / TIF" window.
Unselect Use demux/TIF or select Use demux/TIF, does not matter.
Only work 7.16.9b. Now
All others versions, don't work. So, PC crash.
  • Sat Dec 10, 2016 9:44 pm
#63 by Prog
Is it depended from "Tuner request"?
  • Sun Dec 11, 2016 3:54 am
serkanguzel
serkanguzel
#64 by serkanguzel
No idea, my obviously.
But your custom edited version( 7.16.9b ) is working.
The same problem was reported by @acoloss
Other DVB Players working.
  • Sun Dec 11, 2016 11:44 am
#65 by Prog
Please try change "Tuner request" in dialog on screen and restart ProgDVB. Crash?
  • Sun Dec 11, 2016 2:45 pm
serkanguzel
serkanguzel
#66 by serkanguzel
Prog wrote:Please try change "Tuner request" in dialog on screen and restart ProgDVB. Crash?
Okay master,
I install Pro 7.17.0a
Run ProgDVB PC direct crash.
Restart PC and run ProgDVB, PC direct crash again.
I eject then PC, Geniatech DVB-T2 USB TV card. Run ProgDVB and ProgDVB window opened.
Don't open dialog window/screen !
So, It is not possible to reach dialog "window/screen"
  • Sun Dec 11, 2016 3:29 pm
#67 by Prog
I am mean in good version " 7.16.9b"
  • Sun Dec 11, 2016 3:41 pm
serkanguzel
serkanguzel
#68 by serkanguzel
Yes master,
Only version 7.16.9b is running.
  • Sun Dec 11, 2016 4:00 pm
#69 by Prog
And still running if you change "Use ITunerRequest" in dialog on screen?
  • Sun Dec 11, 2016 4:16 pm
serkanguzel
serkanguzel
#70 by serkanguzel
Prog wrote:And still running if you change "Use ITunerRequest" in dialog on screen?
Yes master,
Select "Use ITunerRequest" Restart ProgDVB and
and Running...
  • Sun Dec 11, 2016 4:25 pm
serkanguzel
serkanguzel
#71 by serkanguzel
I install Pro 7.17.0b, worked. ( Over install Pro 7..16.9b )
Select and/or unselect "Use ITunerRequest" working.
  • Sun Dec 11, 2016 4:47 pm
serkanguzel
serkanguzel
#72 by serkanguzel
Thanks.
Pro 7.17.1 version, works fine. :)
  • Tue Dec 13, 2016 8:37 am
#73 by Prog
7.17.1 still same like old versions of ProgDVB. I am still not have idea why not depended from BDA settings.
  • Tue Dec 13, 2016 8:51 am
  • 1
  • 2
  • 3
  • 4
  • 5
Return to “Hardware”
Re: Two Bugs in v3 portable
Thanks for report. I am retest that in near time.
Prog, Thu Sep 03, 2026 7:39 am
Hi there. I thought the portable had sorted out a bug I found in the windows app version, but sadly not. It seems that i
fredphoesh, Wed Sep 02, 2026 8:18 pm
Re: ProgTV3 portable
edit
fredphoesh, Wed Sep 02, 2026 7:46 pm
Re: 7.72 — three reproducible…
demux in ini or in gui options. Of course gui more simple. LAVSplitter not used. I am not author of LAV codecs and not
Prog, Tue Sep 01, 2026 3:15 pm
  • It is currently Thu Sep 10, 2026 4:55 pm
