Re: 6.63.02 - HD disappeared
#78
arghhhh!
Installed 70.8 meanwhile, running for a time ( a week?!) in 32bit on Win7-64 - perfectly (even if you have to start ProgDVB even if you dont need it ;-(
Today I really looked Live-HD, left programm open for the recording (Sound=0)
Did an recording manually at SD - whichs works.
Recording from timer didnt, because: ALL HD-entries have gone!
So the subject is ok, but number fails...
A new scan of transponders did ....
any hints?
BTW: which CD????!
