Sorry Prog!Prog wrote:1. No ECM on your picture. Then no way for plugin.
2. Per PID mode looks like very slow. Because usually software (and plugins) send commands for open/close by one PID. Not all pids like in sample from you link.
Have you readed doc specs in the first post?
Please, review the document: http://www.satip.info/sites/satip/files ... on_1_2.pdf
I really need to say this:
1) The SAT>IP protocol has the same functionalities and drawbacks that any USB 2.0 DVB device.
2) Using current "programID" requests the ECM pids are not present in the TS. Yes! but this is tunnable with commands.
3) Using "pid commands" is possible to request the FULL TS (without any filtering) with just only one RTSP request.
4) PID mode is really FAST: When you like to tune a channel, you can request ALL pids that you like in ANY frequency that you like in just ONE RTSP request. Why you say that this mode is "slow"? It's the same that with any BDA device!
I feel that you don't have readed anything about the procotol!
