Prog wrote:"Can you give me more information about "Stucked voltage in C lnb of Diseqc 1.2 tab" ? Of course you must select position in dialog with C Lnb. It is very important. ProgDVB must found this position in tree for detect correct settings.
In the old version 6.70.5, when in the "Diseqc 1.2 Positioner" tab, if you select a Ku lnb antenna to move,
you'll see that the voltage is fixed, dont change when change polarizations. C band lnbs are ok there.
In version 6.70.6, the problem moved: now the Ku lnbs change voltage right, but sadly the C band lnbs
got the ill.
Prog wrote:"About 200ms, I am not sure about 100 for all diseq devices in world
I suggest allow minimum (at least, more than) 100ms, as Options allow even 0ms delay. Thats because that would require a very fast controller to decode message and take actions required. And putting big delays may slow down channel change.
I did a better look in version 6.70.6, this the satisfaction state:
1 - Allow Goto 0 - it's OK!
2 - Not allow Store 0 - it OK!
3 - Stucked voltage in Ku band lnb of Diseqc 1.2 tab - it's OK!
4 - Stucked voltage in C band lnb of Diseqc 1.2 tab - not ok
5 - Set position NN to the
in use satellite when open Diseqc 1.2 tab - not ok
6 - Send full diseqc message according to diseqc tree when open and when change satellites in Diseqc 1.2 tab- not ok
7 - Send only E0 messages by buttons of Diseqc 1.2 tab, no repetitions - not ok
8 - Do correct number of
repetion as understand in Device Options - not ok
9 -
Allow 100ms minimun to Delay Between Diseqc Messages - not ok
10 - Remove the "Positions" button or lock its list, to show ALL numbered sattelites, in Diseqc 1.2 tab - not ok
11 - Send full diseqc commands when change frequency or channels - not ok
12 - Test the 22K tone in Ku band lnbs of Diseqc 1.2 tab - it's OK!
13 - Change name of button "More than one satellite" to "Set Diseqc 1.2 Number" - Not ok
As me and Prog are not English speakers, sometimes hard undertand well, I ask testers to help, and confirm problems (some problems can be issues in my hardware, of course...)
