Hi, I'm trying to show the osd and subtitles and the only option I've got is to use ProgDVB Video Render, but if I select this option after a few seconds (about 5) it crash.
Now I'm watching using normal Video Render, but no osd or subtitles at all.
When I use ProgDVB Video Render the watching is very smooth, so anybody knows why it crash ?.
thanks to anybody.
As usual ...The 1 000 000 $ Questions...
No DVB card ? ? ?
Driver?
Progdvb Version ?
Codec(s) used?
Full relevant details, please.
Magic crystal ball out for polishing ATM ...
No DVB card ? ? ?
Driver?
Progdvb Version ?
Codec(s) used?
SiLencer wrote:As usual ...The 1 000 000 $ Questions...
No DVB card ? ? ?
Driver?
Progdvb Version ?
Codec(s) used?
Sorry dude, you're absolutly right, I was born idiot and I'll die idiot.
So here are the details:
DVB Card: LifeView FlyDVB Trio PCMCIA.
Driver: 32 bits, 2.10
ProgDVB ver.: 4.85.1
Codecs: Elecard.
OS: Win XP SP2.
Computer: Notebook Toshiba A20-S103
hmm , maybe it has to do with the onboard video in your Notebook ...
And as you can read in the forum ....for some users (also win XP installed)there get a quartz.dll error message when they use the progdvb renderer..reason unknown
try one of the vmr Renderer (osd works there too)
or try other codec with progdvb (e.g. ffdshow,dscaler5) -> viewtopic.php?t=604 also with vmr (needs xp) or vmr 9 ...osd works fine here with these
i have suffered from quartz.dll .... but the solution is : * use elecard edition
or *Full install with any graph but (not mainconcept) and use ProgDVB Video render
You're probably right SiLencer, my laptop is old and I assume the video card is not compatible with actual systems.
I'll try other codecs as you said.
Thanks.
Thanks.
