Letter size change problem
Re: Letter size change problem
#1 by Prog
I am working on this problem. Now Skin1 is better for hi-resolution display.
ps: In ProgTV, this problem is completely absent. You can try
  • Sat Nov 21, 2020 12:12 pm
Yes, I plan fix that in near future. But not easy. Old windows API not support hi-res monitors.
  • Sat Nov 21, 2020 12:21 pm
#3 by Prog
btw, you can change ProgDVB.ini file diretly
[Options]
Scale2=150
But can you send me screen of bad interlace. I am not can repeat in on 300. 300 still good on my pc
  • Sat Nov 21, 2020 2:14 pm
#4 by Prog
ProgDVB.ini.
  • Sun Nov 22, 2020 4:45 am
#5 by Prog
Also you can try resize dialog and reopen
  • Sun Nov 22, 2020 5:07 am
#6 by Prog
You select this path in installation time. But you can search on all disk
  • Sun Nov 22, 2020 12:02 pm
#7 by Prog
ProgDVB.ini in app data folder. For example c:\Users\All users\...
You can enter your activation data. CDID, email, name. Ask me on email about activation problems.
  • Sun Nov 22, 2020 12:26 pm
Re: Вывод звука wasapi и asio
  • It is currently Mon Sep 21, 2026 4:09 am
