Hello
when I switch to full screen mode the screen will damage and the program will be shown with gap and stop
what is wong?
No DVB card ? ? ?
Driver?
Progdvb Version ?
Codec(s) used?
Full relevant details, please.
Magic crystal ball out for polishing ATM ...
Driver?
Progdvb Version ?
Codec(s) used?
ok sorry
ProgDVB 4.85.1
Plugin API version 1.33 (MD - 1.06)
DVB Card : KWorld DVB
Madule API Version : 1.33
Windows 2003
TV Channel : MainConcept
Video Render
AMD Athlon XP 2600, 512 MB Ram and VGA: Radeon 7000
ProgDVB 4.85.1
Windows 2003
Video Render
Thx
First try other Renderer (VMR 9,VMR (needs Windows XP) or Progdvb Renderer)
trying different Codecs (FFDSHOW,Dscaler5 etc..) is also a goog idea ... -> viewtopic.php?t=604
I change the codec to Cyberlink and also test other codec but problem still remained
in Cyberlink it seems the screen is better but the voice is forward than the picture
Have you tried this ? :
does the KWorld DVB card share an IRQ with other devices (see in windows device manager)?
If yes ...moving the card to an other pci slot maybe give a better result...
