Hi.. Some channels with Progdvb Engine sometimes not works or stream video without audio or when launching starts in SD quality and after 4-5 seconds streams in HD or FHD. I've solved this problem using Lib VLC engine that seems work better.
With latest Version of ProgDVB 7.67.2 a big part of channels when playing open a Window out of ProgDVB program ( like a Pop up ) that say VLC (Direct3D11 Output)
You can test with this channel for example , is a free italian channel ( i don't know if is geoblocked) - If need i have other channels to test.
https://qrg.akamaized.net/hls/live/2017 ... /720p.m3u8
I think that is very annoying because is not possiblle to close window, the windos close only if Stop channel.
Is possible to have an option to play this channels like old versions in ProgDVB App ?
Lib VLC Engine Pop Up
