Hello peeps.
First off, I'm glad to have found this IPTV software, windows generally has very poor selection, not like Android where there are some SUPERB offerings, particularly imPlayer... and to a lesser extent TiviMate, both of which I have owned for years. On PC, the most sophisticated, but also very messy and unpleasant to use, is Best Player, but dev has more or less stopped... so I spent the last day installing and uninstalling many windows IPTV programmes, and this one is my favourite, so well done!
I made a short video showing a few of my pain points, but there are things I like a lot, the interface is clean, I like some of the thoughtful options, like Left arrow to bring up channels, Up Down to find, Enter to show and Enter again to make the list go away... I love that's an option as often I'm not sure about a channel and don't want to keep going back and forwards from TV to channel list.
I found another small bug, i think... if you go to a channel which is not already a favourite, click on the screen to bring up the info bar at the bottom, click on the star to add to favourites, this works. Then repeat to remove the star, again this works... BUT if you entered this channel in a list previously as a starred favourite, then navigating to that channel and clicking on the star on the info bar does nothing, it does not remove the channel from your favourites folder. It adds the star to the last favourites folder you saved something to, which makes sense, but if you navigate to a channel that is a favourite in another folder, then clicking on this star does not take it away... it should.
Anyhow, enough for today, here is the video I made showing the two main gripes.
http://videoblurb.com/mp/ProgTV-feedback.mp4
Re: first response feedback
#2Thanks for feedback. It is more convenient to respond to text as in a video.
1. I am not can repeat first problem with ESC. But possible ProgTV window not in focus. Need more details.
2. I think how to repeat it. Can you export ProgTV data and send it to me with step by step instructions?
3. What's wrong with Esc when you're in settings?
