by Juergen
No way to tell.
As the manufacturer is not specified, nor is the full model name, that case may contain anything...
You're going the wrong way. First look for manufacturer or distributor pages with relevant details, then think about shops and sellers.
However, there is a good chance, that device uses BDA drivers. If so, it could supposingly be used in ProgDVB, after the original software and driver package is installed and set up completely. But in many cases DiSEqC would not work then. Same goes for the remote, if it's not available system wide as a MS HID.
BTW, ebay links are getting useless after some time.
And as they are extremely long, they break our page layout.
And they may occasionally even include some private data...
Last idea, 'cheaper' should not be the only aspect for a bargain...
