my problem here which I want you to help me in is that there are number of channels appear like they have a stronge signal, however it don't work at all, why?and how can I make it work?
I'm from Egypt and I'll give you example for the channels that don't work although it have good signals :
" ESC 1 , Ch 1 , Mehwer , Rotana cinema , EDUC 3 , Melody hits , Melody arabia , dream , Alhurra , Nile news , Nile family , ETV "
Could you please help me in this , please? and thank you.
You forgot to mention, what satellite all this is transmitted from, if these are all FTA stations (all the time = 24/7).
Also please include basic detaiuls on your DVB device, ProgDVB version, codecs used and alike.
What happens, if a non working station is updated from channel properties? Do audio and video IDs update or do they vanish?
__________________________________Norma wrote:For my question which was Posted: Sun Apr 13, 2008 9:06 pm Post subject: some of my channels don't work
First of all I'd like to thank you for your quick answer and here are the details that you require as I think
PC: P4, 3.2 GHz, 1.00 GB of RAM, WinXP PRO SP3, 250 GB HD
Used software
Pixel View
PlayTV 700 DVB-S
ProgDVB version 4.45
By Prog
Required version LNB file 4.22
Module API version 1.23
Plugins API version 1.06 (MD - 1.02)
Device DVB Card
But,
Current language file and version of language file aren't mentioned in the Prog DVB help menu (about Prog DVB)
But If you need this "the language from the setting menu is English"
please inform me If there is any information still required and tell me how can I get it thanks for your help
Why did you not answer some of my direct questions?
Juergen wrote:You forgot to mention, what satellite all this is transmitted from, if these are all FTA stations (all the time = 24/7).
the type of satellite is Nilesate 101,102
and when I make update for the unwork channels nothing happens for the audio and video IDs and the details for the Prog DVB are sent before as you required
So, the audio and video IDs always are correct, even if you are NOT getting picture nor sound?
I can't test your satellite positions here, so I can just speculate and try to give hints.
Try to record from one of that non working (uncrypted / free) stations.
If you are receiving valid streams, recording must
work even if codecs fail. You would notice this by growing file size. In such a case, your trouble may be codec related, perhaps due to a video resolution that codec can't handle or similar.
If you are not getting valid streams, file size will stay at zero. If so, check the audio and video IDs of that station, compare with either a working other application, or another tuner, or a table like satcodx.com, or get valid data from the provider's site. Put in the correct IDs for a station manually and test again
Another way of testing an individual ID is the PID recorder. If an ID carries data, the file must grow, no matter what kind of data is getting transported.
In any case, post full details, for that station you have tested on.
This includes results of PID recording and ID comparison with satcodx
This way I hope to get us somewhat closer to the source of your problem.
But the only way is, to go absolutely systematic.
the following are details for some of unwork channels
caption: ESC 1
provider: ERTU
and there is a check on (can update)
Audio sream: English {pid 1206}
Audio channel: Both
Transponder: 3530 : Nilesat 101,102
Frequency: 11765000 KH Polarization: horizontal symbol rate: 27500
LNB: 1 SID: 506 TID: 5 NIT: 2048
PID Table
PMT: 106 video: 28261 PCR:1006 AC3Audio:0
Teletext: 1106 ECM: 0
About EDUC 3 channel:
caption: EDUC 3
provider: NILESAT
Audio channel: Both
Transponder: 0050 : Astra 1A, Sirius 2, Sirius 3
Frequency: 11747000 KH Polarization: vertical symbol rate: 27500
LNB: 1 SID: 103 TID: 1 NIT: 2048
PID Table
PMT: 103 video: 28261 PCR:1003 AC3Audio:0
Teletext: 0 ECM: 0
and thank you because of your hard trying
caption: ESC 1
provider: ERTU
Audio channel: Both
PID Table
caption: EDUC 3
provider: NILESAT
Audio channel: Both
PID Table
Teletext: 0 ECM: 0
provider: ERTU
Audio channel: Both
PID Table
About video pid you wrote 28261 , if that what appear i think this is ur problem . The right pid is 1006 , so try it .
what's progdvb version you use ?!
provider: ERTU
Audio channel: Both
PID Table
OS : Win XP SP2
CPU : P4 Intel 3.00 GHz "HT"
Memory : 2 GB
DVB-S : Sky Star 2 (2.6D) ( 4.4.0 )
Hotbird 13.0°E | Badr-3/4 26.0°E | Nilesat 101/102 7.0°W
Memory : 2 GB
some channels do not work for me also... my problem is that for some reason, some channels do not work with elecaard codec.. i do not know why.. but when i change the codec when on those channels to something like cyberlink, they work...
This may be a hint for trouble with some special mode, data rate or alike, for the codec / renderer, ProgDVB or their cooperation or even declaration in the tables, stream packet headers or alike.
This for, details rule...
thank you
but do you know what was the problem?
the problem was in the video and audio IDs they were wrong and although I made lots of updates and there were no changes,
I guessed that the problem in them and changed them according to book I have and the channels finally worked
thank you
thank you
So one question remains:
How did the IDs get corrupted?
It may be a bug in ProgDVB, or a bad transmission, or some kind of a logical problem on either side, some bad defined ir incomplete implemented standard, to many possible reasons to mention...
But as Prog - as the programmer - needs logically precise and (almost) complete input to try to patch, we have to admit, we still can't provide him enough of this right now...
To get a step further on, at least, it may still be a good idea, to compare with another DVB application and / or a receiver, and to find out, if eventually that IDs are subject to changes - not being constant 24/7 - or alike.
We're talking computer logics here, not any kind of human style randomly erroneous behaviour - at least I hope so
