some of my channels don't work (additional details )
For my question which was Posted: Sun Apr 13, 2008 9:06 pm Post subject: some of my channels don't work
My problem here which I want you to help me in is that there are number of channels appear like they have a stronge signal, however it don't work at all, why?and how can I make it work?
I'm from Egypt and I'll give you example for the channels that don't work although it has good signals:
" ESC 1 , Ch 1 , Mehwer , Rotana cinema , EDUC 3 , Melody hits , Melody arabia , dream , Alhurra , Nile news , Nile family , ETV "
Could you please help me in this , please? and thank you.
First of all I'd like to thank you for your quick answer and here are the details that you require as I think
PC: P4, 3.2 GHz, 1.00 GB of RAM, WinXP PRO SP3, 250 GB HD
Used software
Pixel View
PlayTV 700 DVB-S
ProgDVB version 4.45
By Prog
Required version LNB file 4.22
Module API version 1.23
Plugins API version 1.06 (MD - 1.02)
Device DVB Card
But,
Current language file and version of language file aren't mentioned in the Prog DVB help menu (about Prog DVB)
But If you need this "the language from the setting menu is English"
please inform me If there is any information still required and tell me how can I get it thanks for your help
Why did you open another thread on the very same issue? You should just have replied instead.
The board software does not allow to move postings or merge threads. Now people would have to read through two threads to try and help.
And, what's even worse, after a few other threads and postings, these two threads will get parted by others.
So here's the direct link:
viewtopic.php?t=2618
And why did you not answer some of my direct questions?
Juergen wrote:You forgot to mention, what satellite all this is transmitted from, if these are all FTA stations (all the time = 24/7).
Also please include basic detaiuls on your DVB device, ProgDVB version, codecs used and alike.
What happens, if a non working station is updated from channel properties? Do audio and video IDs update or do they vanish?
I will close this second thread now, quote your reply into the first one.
CLOSED
