hello
i have tried to use progdvb in Windows Vista (32 bit), But i there is a weird problem. When i try to scan channels it doesn't find much channels.
- when i click the lock button it shows a good signal level (70-80-90%) and a signal quality of 100% so far everything is ok, But when i click the scan button it doesn't find any channel.
P.S. in Windows XP i can use the same hardware and same version of progdvb without any problem
Re: weird problem
#2Now what, not much or none at all?redbull86 wrote:...When i try to scan channels it doesn't find much channels.
...But when i click the scan button it doesn't find any channel...
Technically, this makes a really big difference...
Let people know about the DVB device and driver.
If it uses a BDA driver, you may have to check device options.
Inform people about LNB(s) and position(s), switches and alike.
And mention the ProgDVB version(s) tested, precisely.
Perhaps create a helpful signature.
People aren't supposed to re-read or remember all your previous postings, to get an idea.
This really a big issue for ProgDVB on Vista32,
Channels on some TPs can't be searched out (signal can be locked).
The only workaround for this is to tune onto a good channel, then go to it's "channel properties", then manually update the frequency/SR to that TP, then click "Apply", then channels from that TP will be out in the channel list.
BIG ISSUE! BIG ISSUE! BIG ISSUE!!
Windows 7, 64-bit.
Twinhan AD-SP400(1041) DVB-S2.
KNC1 DVB-S2.
Technotrend S2300 Premium DVB-S.
Technotrend C1500 DVB-C.
Technotrend DVB-T TV-stick.
ATI 4550.
Asus Xonar HDAV1.3 Deluxe.
Creative S750 speaker system.
Latest ver.6 of ProgDVB Pro.
KNC1 DVB-S2.
ATI 4550.
I've send Prog sample for this issue, but no finding on his side....
Twinhan AD-SP400 w/ latest driver
lastest version 5 of ProgDVB
Windows Vista SP1 32-bit
Windows 7, 64-bit.
KNC1 DVB-S2.
ATI 4550.
KNC1 DVB-S2.
ATI 4550.
Re: weird problem
#5redbull86 wrote:...When i try to scan channels it doesn't find much channels.
{i can scan only channels with a sr higher then 22500 ksps)
...But when i click the scan button it doesn't find any channel...(this happens when i try to scan manually channels, it happens on channels which have a sr lower then 22500 ksps.)Now what, not much or none at all?
Windows Vista (32bit)Technically, this makes a really big difference...
Pinnacle PCTV 450e DVB-S USB box
driver version 1.0.2.4 (BDA driver)no switchInform people about LNB(s) and position(s), switches and alike.
sattelite at 42.0 WestAnd mention the ProgDVB version(s) tested, precisely.
latest version of progdvb 5.16 (also tried different versions of ProgDvb)Perhaps create a helpful signature.
On the German pages of pinnaclesys, the deivises don't have numbers.
So, could you perhaps point us to the correct page for technical specs?
What minimum symbol rate is specified for that device?
this is the driver pageOn the German pages of pinnaclesys, the deivises don't have numbers.
http://cdn.pinnaclesys.com/SupportFiles ... mePCTV.htm
a direct link to the driver
http://cdn.pinnaclesys.com/SupportFiles ... a32_64.zip
i coudn't find a page with technical information about the device.
where can i see that?What minimum symbol rate is specified for that device
P.S. in windows xp i was able to watch all channels with a starting symbolrate of 2050 ksps up to 30000 ksps.
As long, as you don't know how, please don't use BBCode here.
You did mix things up completely, and I just had to correct several misleading things, like wrong quotes on what I never said.
And don't try to change colours, if that's not important for the message's content.
___________________________________________________________
However,
So the whole issue must be driver related, no more, no less.
Not ProgDVB related.
However,
You should have mentioned that in the beginning.P.S. in windows xp i was able to watch all channels with a starting symbolrate of 2050 ksps up to 30000 ksps.
