hello ,
can this function be possible ?
i mean to watch a channel like BBC & have Audio from another channel
Thanks
Of course this can only work on the same transponder.
Instead of adding the Audio PID, just edit the existing one.
If more than one exists on the station, edit out the others.
Then set the channel properties to not update.
Store.
Close ProgDVB and restart it.
Now it should work.
Store.
Now it should work.
ok i did all the stuff even rebooted my pc & still not got audio
here live what i did , frequence 11179 H 27500
channel 1 : Telelotto (PID=626)
channel 2 : Telemarket (PID=771)
ok i went to Telelotto i want his video + audio from Telemarket
i changed the value 626 by 771 saved close prog
lanched again progdvb went to Telelotto no audio found..
anyway this is a test of same transponder
but i need from different transponder is that is possible
Thanks
Thanks
Just a minute ago, I've tried exactly this over here.
And it did work easily, on ProgDVB 4.75, which is the latest version, that supports my Nexus' hardware features (almost) fully, and therefore is used here by default.
(OT: As I'm still running (a highly modified version of) Win98SE right now, for expensive hardware compatibility reasons, I will not retest on a more modern version through the following couple of days. My other machine does not have satellite.)
Did not even have to close and restart or anything else. Just switched channel back and forth once.
BTW, this old version won't read transponder tables at run time, so no auto update, except of scan time.
To avoid an unwanted update, set station to not update, and perhaps also edit the SID to an invalid value like 8191.
Anyway, I won't want to watch any of those stations, even if someone gave me money for this ...
But of course, that's no more than my personal point of view.
actually this not even my wanted channel but just a simple test ...
i just want to see this functionallity working for me on my Progdvb pro version .
that's all what i need & i'am open of all suggestion how to make it work
i'am using version 6.24
Pro version issue.John wrote:i just want to see this functionallity working for me on my Progdvb pro version
So I'm out of this thread now.
Prog, where are you?
