M-16 wrote:They are numerous. Here are some of them:
AVS Video Converter
GOM ENCODER
Daniusoft DVD & Video Converter Pack
and so on...
These encoders are for processing of already recorded video
If you need to decoce the video/audio in ProgDVB this issue was widely discussed here on forum. I'll just name some name of the decoders' packs:
MainConcept DTV Coder pack
СyberlinkPowerDVB (CLVD Pack - 06.01.2011)
ArcSoft Encoder pack
Microsoft DTV-DVD video/audio decoder (included in Windows 7 all releases)
Ok sorry i was thinking taht reinstalation was meaning to uninstall progdvd elecard codecs and reistall everything back.Abot the mpeg that i'm speaking that i got after recording chanell dtt tv with progdvb i try to use:
Allok AVI MPEG Converter (and stop on 100% but the program dident close so the "convertion was not corrected done)
Then i tyied olso Ultra Video Joiner with this was ok 100% the program just cutted off a big part of the lasy "part 2of the mpeg2 file
I tryied olso as i wrote on the begining of tyhe post viartualdubmpeg2 but nothing i think that if the file is curraped then the problem is not tyhe program i use to convert it the problem is why the file came out currapted!
Ok by the way i have uninstalled progdvb,elecard plugins and ProgDVB SolveigMM MPEG cutter I will reinstalla again forst progdvb then the plugin the the ProgDVB SolveigMM MPEG cutter maybe that will sort out everything.I will let u know.
Thank's
Helen
PS:Unfortunately nothing to do.I uninstalled everything then i installed:
1)Progdvb
2)Elecard MPEG-2 PlugIn for WMP 4.1.100318.
3)SolveigMM_Video_Splitter_2.2.904.16
still getting that error nd with my lcd tv Sansung le32c450 says file bnot supported instead before was all ok realy dont know what to do more
