crash when chose enable cam interface
A.S
A.S
Fri Apr 01, 2011 12:45 pm
#1 by A.S
Hi
I have problem that when I chose enable cam interface the app crash
my dvb-s card is technotrend 3200 HD
thanks
  • Sun Aug 21, 2011 7:15 pm
A.S
A.S
Re: crash when chose enable cam interface
#2 by A.S
any idea :cry:
  • Thu Aug 25, 2011 8:17 pm
#3 by Prog
I have 2-3 same reports but not have good idea :( What last good version of ProgDVB for you?
ps:Same problem in last prerelease?
  • Fri Aug 26, 2011 5:02 am
A.S
A.S
#4 by A.S
thanks fo your reply
I don't Know which is the good version of progdvb for me because I've purchased an irdeto card Two weeks ago.
I've tried the last prerelease and the same problem happen
  • Fri Aug 26, 2011 8:13 am
#5 by Prog
Try some 6.6x or 6.5x ProgDVB.
  • Fri Aug 26, 2011 9:08 am
A.S
A.S
#6 by A.S
I've tried 6.6 and it not crash but the latest version better than 6.6 :)
  • Fri Sep 02, 2011 7:00 pm
A.S
A.S
#7 by A.S
still a same problem in the latest version :cry:
  • Sat Sep 17, 2011 3:45 pm
A.S
A.S
#8 by A.S
I've found a way to run the app.by uncheck set last channel in the startup settings.
  • Mon Oct 17, 2011 6:02 pm
#9 by Prog
Hm. ProgDVB set first channel to fast? Do you have any command line commands?
  • Tue Oct 18, 2011 7:05 am
A.S
A.S
#10 by A.S
No I don't have
  • Tue Oct 18, 2011 3:15 pm
  • It is currently Tue Aug 25, 2026 12:38 am
