1- In version 6.73, i found a problem with blind scan using tbs module:
- it is cutting the voltage to the lnb when starting blind scan. To my understand, this should not happen, lnb voltage must remain 'on' while the receiver is turned on.
I observed it as my diseqc 1.2 controller detects this condition and halts its operation until voltage is completelly off for some time. This is to prevent microcontroller malfunction and tear out of motor parts.
2- regarding to the blind scanner, it needs some more inteligence, as it is generating many new channels with small offset in parameters. For example 1 MHZ plus / less, 1 K symbol rate count plus / less, seems a new, but is a present channel.
Well thats enough today
