ProgDVB6.85.3Pro "Device not started" with Hauppauge DVBS
System Win XP 32 bit
Device "Hauppauge WinTV 88x DVB-SS2"
ProgDVB6.85.3Pro
What I did: Uninstalled ProgDVB6.84.5Pro with ProgDVB/Uninstall.exe and removed all Settings.
Started fresh Install of ProgDVB6.85.3Pro.exe
Run ProgDVB as Administrator, added the DVB S card as BDA device and got "Device not started" error.
Verified the Card with Hauppauges WinTV7 - worked (picture and sound).
Tried various restarts of ProgDVB (error reports attached ProgDVB6.85.3Pro.exe_Crashes.zip, BDA Driver 2.38)
Remembered that I had an previous backup from Prog DVB BDA.Device (1.44). Copied the old version into the modules Directory.
Now ProgDVB starts (BDAv1.44.png).
Could you please check your BDA Driver 2.38?
Crash reports og 6.85.3
(170.68 KiB) Downloaded 595 times
