"SNR value in decibels" Is possible to add ?
Example Picture ;
Regards.
Just right.Prog wrote:It is very depended from device. Not all device give more one value...
Yes master,Prog wrote:But it is really need for watch TV?
Hey man,zhenya_hacker wrote:Is it really needed to watch TV? Mostly it is needed while tuning dish or when there are problems with TV image. In this case you can use special software like signal analyser you screenshoted.
So, can see in real-time. ( concurrency )serkanguzel wrote:
Realistic signal level, can be seen only with the db.
Dear master,Prog wrote:Not realistic. This this value from tuner. One device can show 20 other 30 on same cable.
