Remote control AVerTV Volar HD 2 doens't work
FCazs
FCazs
Fri Dec 18, 2015 12:30 pm
#1 by FCazs
Have AVerTV Volar HD 2 and remote control doens't work for progdvb
  • Fri Dec 18, 2015 12:33 pm
Re: Remote control AVerTV Volar HD 2 doens't work
What type or RC? Is it working like keyboard?
  • Fri Dec 18, 2015 12:39 pm
FCazs
FCazs
#3 by FCazs
This is the model we use http://www.pccomponentes.com/avermedia_ ... r_hd2.html
And image from remote control is this
not tried with the keyboard, it makes no sense for me to use, from the bed.
Tell me if I can provide any more information and where
  • Fri Dec 18, 2015 1:01 pm
#4 by Prog
I try ask avermedia. But check Settings->[... options]. Must be selected AverMedia.
  • Sat Dec 19, 2015 5:37 am
#5 by Prog
Ops. Avermedia recommend use AVerLirc for kook keys and routing to software.
  • Sat Dec 19, 2015 5:39 am
FCazs
FCazs
#6 by FCazs
Thanks im go to test if work thanks!!
  • Sun Dec 20, 2015 8:21 pm
FCazs
FCazs
#7 by FCazs
I tried to make it work, but not how to do it, you could explain?
  • Sun Dec 20, 2015 9:18 pm
#8 by Prog
I think this tool is winlick server. You can try setup winlirc client in ProgDVB (Options->Controls->RC plugin)
  • Mon Dec 21, 2015 4:12 am
  • It is currently Mon Aug 24, 2026 1:56 pm
