Progdvb service won't start
Hi, I just bought your software, all is fine excepting that I can't start progdvdservice.exe ... even when trying to start it manually, it won't and stop right away.
So I must keep PrgDVB running if I want to schedule recordings.
I'm on WIN10 Pro ...
Any idea why ?
Cédric
Re: Progdvb service won't start
if I try to manually start ProgDvbService.exe with admin rights, it tells me It fails
If I go into the task manager udner the services tabs, it always shows as 'stopped'
and if I try to start it, bim, it directly stops.
If I go to the services manager and try to start it from there, it tell me it started and then stopped.
by the way I use ProgDVB Network Edition x64 7.26.08
I could find this in Administration Events (nothing elsewhere) :
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="ProgNetScheduler" />
<EventID Qualifiers="0">0</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2019-02-05T15:21:56.096955800Z" />
<EventRecordID>8784</EventRecordID>
<Channel>Application</Channel>
<Computer>OMENCP</Computer>
<Security />
</System>
- <EventData>
<Data>Le service ne peut pas être démarré. System.NullReferenceException: La référence d'objet n'est pas définie à une instance d'un objet. à NetSchedulerService.ServiceTools.LookApplicationDataPath() à NetSchedulerService.ServiceTools.GetApplicationDataPath() à NetSchedulerService.ServiceTools.GetLogsDirectoryPathAndRemeveOld(String fname) à NetSchedulerService.ServiceSchedulerManager.Start(Boolean is_console) à NetSchedulerService.Service1.OnStart(String[] args) à System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state)</Data>
</EventData>
</Event>
