    • Unanswered topics
    • Active topics
ProgDVB 5.13.5 Sound and record problem
  • 1
  • 2
redbull86
redbull86
Wed Sep 19, 2007 9:58 pm
#16 by redbull86
Prog wrote:It work on my PC. Elecard audio codec.
yeah that's correct the channel itself works correct but it causes that other channels are not working correct
if i never switch to that channel and i only watch other channels then there is no problem
  • Fri Mar 28, 2008 7:29 pm
  • 1
  • 2
Установил мобильную ПрогТВ, удалил из папки два шрифта, скопировал свой файл шрифта - не работает. Шрифт в программе обы
kostan, Sat Nov 08, 2025 10:06 pm
If this is what you mean, yes i can send you the file, just tell me how, Thanks. I've sent the logs to the de
nikspk, Sat Nov 08, 2025 7:38 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new
AndresMaxx, Sat Nov 08, 2025 5:48 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new a
nikspk, Sat Nov 08, 2025 4:59 pm
  • It is currently Sat Nov 08, 2025 11:39 pm
