Hi Prog
1. When switching between channels with a different resolution on some channels i don't hear sound anymore (picture is good). When i close ProgDVB and start it again then that channel has now sound (if i switch to another channels and back then the same problem occurs again).
2. While recording from a channel the picture freezes for a while and then it plays normal and againt it freezes and so on.
I see theese problems on ProgDVB 5.13.2 and higher versions.
P.S. i have deleted that file but now some channels don't have both pciture and sound
only a black screen
Also when i try to play a recorded file in Windows Media Player the picture freezes and there is no sound
#7it didn't helpProg wrote:Please try update ProgDVB
still no sound when switchin from this channel at 42.0 on transponder 11996 sr 26000 to another channel. This channel which i suggest caused all this problems has a resolution of 352 x 576 (width 352 height 576}. on previous versions of progdvb i coudn't watch this channel i saw only a black screen and no sound. On the newer version this channel has a good picture and sound but this costs that the other channels aren't working correct now which were working fine on previous versions
P.S. When i close ProgDVB on one of the channels which have that sound problem and i start the program again the channel now has sound.
P.S. only on ProgDVB version 5.12.8 i think every channel was working fine. (but i don't have this version anymore)
#9yes it is AC3 sound.Prog wrote:It is ac3 sound? Please record 30-40seconds of channel to TS format and put on http/ftp.
there's no sound problem while playing the recorded files in Windows Media Player. so if i upload such file you will hear normal sound.
Only when watching the channel directly there is a sound problem. when i record it and i play it in Windows Media Player everything is ok.
it seems now i can use ac3filter for ac3 sound i'm now not getting any error message.
the problem now is that when i select another audio codec the channel has now sound but when i switch to another channel and i switch back, the channel again doen't have sound. so i have to change it again to another codec.
i have tried all available audio codecs but it seems there's a problem when switching from a channel which uses ac3filter to another channel which use for example elecard audio codec. otherwhise when switching from a channel which uses elecard audio codec to a channel which uses ac3filter there is no problem.
P.S. when i go to the options>Direct Show menu and i click to ok button without making any changes the channel has now sound but i have to do this every time when a channel doen't have sound
