Hi again,
I tested a while and tosheva's idea seemed to be right. The effect is caused by the DS-demultiplexing namely empgpdmx.ax.
Close ProgDVB go to the Plugins Folder and unregister the empgpdmx.ax by using regsvr32.exe /u empgpdmx.ax
You should see a message like "unregistering empgpdmx.ax was successfull". (You can always undo this by calling regsvr32.exe empgpdmx.ax, without the /u parameter).
Just deleting the file will cause playback problems but now, everything works fine.
If anyone could please tell me, if I can still create own graphs somehow, I would appreciate that information.
P.S.: If you have a Radeon HD-Series graphic card, a very good Image can be achieved using the Radeon AVIVO Codecs and fine tuning the settings using Catalyst => Video Settings. I have a sharp, clear image, no de-interlacing artefacts and images are very fluid. The CPU Usage is below 10%.
#18
in older ProgDVB Versions you could use graphedit to create your own graphs ==> which meant, you could select any media file (in our case a transport stream) select the mpeg Splitter, the audio decoder, the video decoder (...and add sound/video-effects etc. if you wanted) and then save that graph and select it in ProgDVB. So you could much more precisely define, which splitter/codec/renderer combination you want to use for certain media types.
Look at this to see what it looks like:
http://www.steffen-klausing.de/content4 ... artlang=de
Our change channel problem seems to come from the fact, that ProgDVB selects any MPEG-Splitter available (probably the Elecard MPEG Push Demultiplexer named: empgpdmx.ax). By unregistering/deleting this file ProgDVB will use the next available splitter - but I don't know which one that is.
#19
Hello,
same problem for me, but I solved it with rename the file empgpdmx.ax.
I didn't have to unregister it, because the MPEG-Splitter wasn't registered in my system.
Now everything seem to be OK. No black screen after changing channel.
A perfekt Software!
Flansch
A perfekt Software!
Flansch
#20
I want to say this problem is solved for me since the ProgDVB6.20.5Std version!!!!!!!. Thanks for correct that error!mnmlnet wrote:Prog, with debug nothing change, the problem is there.
I have also this problem since I started using ProgDVB. Not in all channels, but allways in the same channels.
With my 2 device cards, an "Avermedia volar-x" and "my new Pinnacle Nanostick" the problem is the same.
A comment that perhaps help you, Prog: Curiosly when I change to a channel with this problem and I have the black screen if I open the menu Options and I make clic in "accept" the problem disappears for this channel, not for the other with this problem.
Also if I close the Progdvb and I open again it, if this channel is selected, the problem disappears for this channel, until the next time than I select again changing of channel.
I think is a bug but update after update the problem is not fixed.
#21
Yes, I can confirm this too!mnmlnet wrote:I want to say this problem is solved for me since the ProgDVB6.20.5Std version!!!!!!!. Thanks for correct that error!
