Re: TBS-5925 and Multi Input Stream
#18i have the same problem with my tbs 5925 and progdvb prof 7.02.04 .not scan pls frequences.i make the 3 files BDA.Device,TBS.EBDA and TBS.EBDA2 from version 6.93 and work perfect . but with this version prog media server not work anymore.i have regristered version of progdvbpro and prog media server pro small.please fix this in one new version.
#20yes this is my Grande Fratello channel.please fix it.thanks
Eutelsat 5 West A
Premium Extra 1
12606.00 V KA3 Super DVB-S2
PLS: Root+8 8PSK ACM/VCM
Stream 1 29900 2/3 Mediaset3, 24.9 Mbps
Waht is the problem?
Eutelsat 5 West A
Premium Extra 1
#22Thank you very much.Now work very good with Tbs 5925 and Prog DVB 7.02.04d and PLS !!!
#23Hi to all,
have TBS-6925 latest driver and Progdvb latest version
but not select PLS!!
Help thx.
#25
But not select the option PLS
My system is Windows 8.1 x64 EN Progdvb 7.03
#26Hi Prog,
Test with ProgDVB 7.0X, but cannot hit "Physical Layer Srambling in manual search !
Thanks for reply
Regards
Thanks for reply
Regards
- PLSa.png (26.83 KiB) Viewed 7185 times
#27Hello,
1) With ProgDVB 6.93e or 6.94 and my TBS 5925, I can receive MIS transponders with or without PLS.
But sometime when I scan a transponder, I have this message "ProgDVB engine restarting!"
2) With versions 6.95 and 6.96 , I cannot receive MIS transponders with or without PLS, no signal !
With "normal" tranponders DVB-S or S2 no problems.
I use Windows 8.1 - 32bits.
TBS Drivers 1.0.1.9
TBS Drivers 1.0.1.9
#29Hi,
The best way (for me) to receive MIS transponders with or without PLS is ProgDVB 6.96.2 with 2 modules - BDA.Device(315ko) - TBS.eBDA(172ko) from ProgDVB 6.93e.
With versions 7.0X :
1) Cannot hit "physical layer srambling"
2) Sometime no picture, have a green or grey screen !
3) When I receive a transpondeur in MIS and go to a DVBS2 (no MIS)transponder, I have no signal...restart ProgDVB and it work.
I use Windows 8.1 - 32bits. TBS Drivers 1.0.1.10.
