i have new problemt. i use old list. when i change format video.the Chanel is change and only chanel display. please https://youtu.be/phRz5AXC4Cw
Scan can't finish
https://youtu.be/dVhpn9GEF3Y
Re: Help me use Progtv
#171. Not clear for me. You change playback mode (only for current channel).
2. Try wait 20 minutes more. Still no result? Looks like scanner working but UI not updating.
#18Ho,my english not good
1.i change playblack mode and only current chanel ( you can see video posted)
2.i try scan many time,each click Stop it out.and it not update Blind list.you can see video posted
Thank you
Thank you
#191. Yes, this menu only for current channel. For all channel in Options->Engine->...
2. About scanner. I am check again in near days and send you test version.
#20Thank you for reply.
1. I want question.why do change playback mode then chanel floward change?how i can fix change it.
2. I wait good new.
3. The current chanel list use by wifi,when i connect LAN network it don't play
2. I wait good new.
#211. Playback mode is per channel option. Global one in Options->Engine
2. http://test.progdvb.com/74/progtv.adv.2.19.3.apk
3. It is not depended from ProgTV.
#22Thank you for all
Your app verry good all app play iptv
I can more question for you?
Mychanel have some high definition 1080.when play chanel(1080) is lag.the now i want down to high definition 720.
Thank you
Thank you
#24Hi,thank you
I don't know,the deffirent between iptv and ott.because i use http://ottplayer.es.can you tell me for that?
App new you send to me have misstake.option display don't use letter box 16:9, i choiced but don't change.
Thank
Thank
#27I don't clearly provider,you can for example it.
I use list m3u upload on website ottplayer.es,then i download ott on chplay,i login on app OTT when app OTT connect with website and play mylist uploaded.
And app ProgTV,i don't know use it
Thank
Thank
#29here mylink
http://textuploader.com/5iv8a/raw
and here file log play on win
and video play on win (i play local network udp://@)
https://youtu.be/ibgJRuc7m54
thank
thank
- Logs.rar
- (34.12 KiB) Downloaded 333 times
