hi every one
The firttime thank you developer created app Progtv
I use Progtv android
I have just know it. In time use,i have some question.please help me
1.i use function Iptv blind search,it search about 5 minute stop.
2.i don't know to use DVB over IP,Start>IP abd ProgtvIPTV client.
3.i have Ip : udp://@225.1.1.xxx.only sound and screen black.( i change play media 'ffmmp' then drop image)
Please help me.
Thank for all.
Re: Help me use Progtv
#21. Crash or? Please send me logs (Options->Debug->Logs before that that)
2. You must have some SAT>IP or "DVB over IP" source (software or device).
3. What video format? Same problem with OpenMAX mode?
#3Thank for reply
1.i will it when i comeback home
2.i don't clearly.please to some source
3.format video. I use three:openmax,media and ffmmp (when i switch 'ffmmp' i see 1920x1... MPEG
Thank
Thank
#4Iptv not see
udp://@225.1.1.44:30120
udp://@225.1.1.45:30120
udp://@225.1.1.46:30120
Please test.
Thank
Please test.
Thank
#5multicast is local links. I am not have access from out from your network.
#6Use list m3u
#EXTM3U
#EXTINF:0
#EXTING:0
and save file.m3u
P/s:use wifi play it,don"t play LAN
#EXTM3U
#EXTINF:0
#EXTING:0
and save file.m3u
#12log-data of me.please see and help me
Thank
Thank
- Logs.zip
- (87.05 KiB) Downloaded 308 times
- progdvb_data.zip
- (108.46 KiB) Downloaded 260 times
#14Scan about 3-5' stop of 20'
See udp://@225.1.1.44:30120,only sound,screen black. It display stereo-mpeg
#15Mistake more.i see when box use wifi connect to router if box connect lan with repeater don't play ( i use 02 device:router wifi and repeater)
