Re: TBS-5925 and Multi Input Stream
#33
Hello Prog,
I'm back...
2 Tests with ProgDVB 707.01 and new drivers from TBS - 2.0.0.3
1) On 13°east 11919 v 27500 MIS stream 1 and 2 without PLS, I cannot detect streams and of course I cannot lock and scan !
2) On 5°west 12648 v 29500 MIS Stream 1, 2 and 3 with PLS, I cannot hit Physical Layer Scrambling and than cannot introduce value and cannot Lock and scan !
I send you a log
All work fine with ProgDVB 6.96.2 with 2 modules - BDA.Device(315ko) - TBS.eBDA(172ko) from ProgDVB 6.93e
Thanks for reply
Regards
Logs.zip
(12.72 KiB) Downloaded 237 times
#36
Hi Prog,
Test with 7.07.05
To receive channels (previously scanned with 6.92) in MIS with or without PLS, it work.
But after receive one on several channels in MIS with or without PLS, cannot receive any channels in DVB-S2 normal (no MIS)! I have to restart ProgDVB and hardware reset TBS !
With manual scan :
MIS without PLS cannot detect any streams and of course cannot scan!
MIS with PLS cannot hit "Physical Layer Scrambling" this one stand in "grey" and...cannot detect stream and scan !
Since 7.xx versions level and quality are lower than version 6.92 - 20% to -50%
Regards
stp
