Re: ProgDVB64 and ProgDVB32 crash on Vista 64bit and Win7 64
#50
On Win7 _64 ProgDVBx32 version 6.81 crashes very similar to the 64bit version. The log is attached.
Could it be that ProgDVB is getting confused with 32/64 bit as the crash happens in kernelbase.dll of SYSWOW64 dir and not system32 dir?
I am still using Terratec Cinergy DT USB XS Diversity with driver version 3.12.00.00.a; of which the drivers are installed in system32/drivers dir.
Can't you check what goes wrong on a test machine using this HW/SW?
Which HW/SW and which codecs can you recommend/have been tested?
Logs.zip
(1.05 KiB) Downloaded 302 times
#51
Prog wrote:wmc, dvbdream,winTv7 is win32. Why you compare they with ProgDVB x64? Test ProgDVB x32 also.
I don´t compare they at all, just said it to confirm is not my card or drivers problem, because with those programs works. :|
I could use one of that, but I like ProgDVb more, so I asked for the solution...
If you need any log file, or I can help in any way, just let me know. Anyway, I will try to reinstall progdvb in a clean win7 , maybe old drivers or codecs are interfering.
I tried ProgDVB 32, same problem. :cry:
#56
I installed the free x64-version 6.82 and ran dependency walker. At first it complained of a missing ieshims.dll (belonging to Internet Explorer 9). After adding the IE dir to the path this complaint was gone, but it says:
"Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module."
What does this mean? ProgDVB crashes as before, the log is attached.
Logsx64.zip
(670 Bytes) Downloaded 276 times
