ProgDVB64 and ProgDVB32 crash on Vista 64bit and Win7 64bit
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
Pythia
Pythia
Fri Feb 03, 2012 1:52 pm
Re: ProgDVB64 and ProgDVB32 crash on Vista 64bit and Win7 64
#76 by Pythia
michael46 wrote:The main window doesn't even start, I only get the attached message.
Igot the same problem.
  • Fri Feb 03, 2012 2:15 pm
michael46
michael46
Sat Jul 18, 2009 8:58 pm
#77 by michael46
you have seen the last answer: it seems that ProgDVB development surrendered!
  • Sat Feb 04, 2012 5:30 pm
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
Re: What is the way to activa…
I am not remember what driver type use 3650. Do you use select {bda} xxxxx in TV sources of ProgDVB? 1. Check propertie
Prog, Mon Mar 30, 2026 12:34 pm
ProgDVB must support this CI without plugins. Do you use BDA or WDM driver? Try WDM at first. WDM? Try it. How do
nasser, Sun Mar 29, 2026 7:45 pm
Prog, Sun Mar 29, 2026 6:48 am
Try x32 version of ProgDVB. Check Settings->CI Do you mean this version? ProgDVB + ProgTV x32 for x32 or x64 Windo
nasser, Sat Mar 28, 2026 1:39 pm
  • It is currently Wed Apr 01, 2026 11:51 am
