hi,
I'm trying to understand how ProgTV works.
I'm streaming to an android device but have I to keep ProgTv for windows always open in fullscreen?
I moved the ProgTV(for win) window to another monitor but now when I try to open the options in order to move the window back to the primary monitor, I can no longer see the option window. I mean that I think the option window is opened but I cannot see it, neither using Alt+Tab, I can only press Alt+F4 to close it
Re: ProgTV
#3uhm... I try to rephrase...
I see that in order to stream to a mobile I need to keep opened ProgTV or ProgDVB.
why? is this normal? can't I stream without launch one of them?
secondary question: I have 2 monitors, I moved the ProgTV window into the secondary, but now when I click again Settings - 6 Option in order to move ProgTV back to the primary monitor, I cant place the option window foreground and as ProgTV is in fullscreen I cant see it.
I'm stucked in this situation, can I hve some help?
Re: ProgTV
#41. Yes. Need ProgDVB. You can use it without playback of channel. Options->Main.
2. I am not can test now. But try change video renderer.
Re: ProgTV
#51. ok but if I use the "open channel without playback" option I can no longer see the images on windows. So its not so useful, it would be nice a button to switch the render on/off, or better if the renderless is applied only when I stream.
2. /SOLVED/ change video render? how? I can't reach the option window.
Can I maybe manual edit some ini file, something like for example "config.ini /choose display=1"?
edit: ok I've reinstalled all and now ProgTV came back to the primary, I'll never move it again.
https://www.dropbox.com/s/7jmnyc2ggybgu ... 2.png?dl=0
