BlindScan; In the search, "Symbol rate"; Adding auto-selectable feature.
Example ;
By definition; 0 - 45000, as it would describe ...
This feature; there are SmartDVB and DVB Dream.
We want to see/use it type on your program.
Re: Addition automatic selective "Sembol Rate" for BlindScan
#2Please remember me about that in august.
#3Okay.Prog wrote:Please remember me about that in august.
#4Hi my master,Prog wrote:Please remember me about that in august.
Thank you in advance for your works.
#5Btw whathe value other software send to auto symbolrate?
#6min : 0 ( zero )Prog wrote:Btw whathe value other software send to auto symbolrate?
max : 45000
Or higher.
Related "BlindScanners" and "DVB players" capable of full BlindScanning ;
BlindScanners : EBSpro, Crazyscan, IQmonitor,
DVB players : DVB Dream, SmartDVB
#8No. Busy by site and other task. But send me logs of Blind search. Is it use ebda2?
#9Hi master,
I can not send it now. Because, my home address changed. I have not establish a dish antenna yet.
But if there is a friend who wants to deal with this, I think he can send a "log file".
If you have a dish antenna, you can do this operation too.
As a result, Full BlindScan programs ; SmartDVB, DVB Dream, EBSPro, IQmonitor, Crazyscan
Limited BlindScan programs ; ProgDVB, TransEdit
So, we expect an effort from you too in this regard.
Regards.
Regards.
#10Hi @Prog,
Is it possible to start adding this function ?
#11Not now. Not many users use blind search for DVB.
btw, what source you use? Cable or satellite?
#13No fixed symbolrates for DVB-T in your region?
#14My region, Kyrgyzstan. There is DVB-T2 terrestial.
Terrestial, so DVB-T2, no problem full blindscan.
But, DVB-S2 need full blindscan. E.g; like it's in the same crazyscan ...
