AC3 Codec Problem
joe_nilo
joe_nilo
Mon Jun 26, 2017 5:42 am
AC3 Codec Problem
#1 by joe_nilo
Hi,
can you please introduce a Codec or a way for AC3 Audio Format?
tnx
  • Mon Jun 26, 2017 5:49 am
Re: AC3 Codec Problem
Android not have normal codes. But check ac3 in options - debug - codecs
  • Mon Jun 26, 2017 5:40 pm
Roby1164
Roby1164
Fri Jun 23, 2017 2:52 am
#3 by Roby1164
It also lacks audio support for DTS ..... It's not an Android problem, as with other App Player, it works, you hear audio, both AC3 and DTS ....
BULLSHIT gГ©nГ©rique forum pharmacie www.viagrasansordonnancefr.com
  • Tue Jun 27, 2017 3:01 am
#4 by Prog
It is license problem. I am not like pay for ac3. Google and half of device manufactures not like also.
  • Tue Jun 27, 2017 5:35 pm
Roby1164
Roby1164
#5 by Roby1164
In the codec list of your app, you just notice that audio formats, AC3 EAC3 and DTSHD, are under AML and not OMX as the others !!!! What does that AML mean?
  • Wed Jun 28, 2017 3:05 am
#6 by Prog
What list you mean? Screen?
  • Wed Jun 28, 2017 6:17 am
Roby1164
Roby1164
#7 by Roby1164
Prog wrote:What list you mean? Screen?
http://prntscr.com/fpyrvx
  • Fri Jun 30, 2017 7:23 am
#8 by Prog
Not bad. Is it working if you disable Engine in playback options?
  • Sat Jul 01, 2017 5:43 pm
Roby1164
Roby1164
#9 by Roby1164
Prog wrote:Not bad. Is it working if you disable Engine in playback options?
Disable Which Engine? ProgDVB?
Tried this too, but there continues to be the message, "Audio not supported ...."
  • Mon Jul 03, 2017 3:48 am
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 12:59 am
