hi all, for days i had 5 tuners on and progdvb has record great
for days and days.
yesterday i wanted add the other 3 tuners, for increase the
capacity to take channels from other mux.
so, i turn on the sixt tuner and i search all channels.
when has finish, in the menu i see the same channel
on 6 tuners (example dmax).
but when i try to click on the channel for view,
progdvb crash like a flash, without a window error.
after many and many tries, format pc, ecc.
i return to turn on 1 tuner after 1 and i stop
at 5 tuners.
finally i watch and record from all 5 tuners
and progdvb don't crash never.
when i have try to turn on another tuner (six tuner total),
progdvb crash like before.
clear that the program is write bad and don't support
more of 6 tuners.
thank and i hope that you can fix the program.
Re: TBS 6209 work only 5 of 8 tuners
#2Try update driver. Same problem on some old TBS with 4x tuners.
ps: Please send me logs of crash.
#3this is the log when i try to turn on the sixt tuner.
- Logs.rar
- (8.28 KiB) Downloaded 395 times
#4Looks like crash on first channel? Please look in system logs. What dll is crash?
#5the problem is not that crash for the first channel.
the problem is that when i have turn on 6 tuners,
just i touch 1 channel, the program crash.
can you be more clear ???
system logs ???
where is this file ???
logs folder, and after ???
system logs ???
#6listen:
where is the file where i can go to check if the program run 8 tuners ???
i can try to touch the program inside programdata-progdvb-etc...
maybe i can solve the problem for the crashes when i try to
have 6 tuners on.
thank.
have 6 tuners on.
thank.
#7DevID=80016499.04
DevID=80016498.04
DevID=8001649B.04
DevID=8001649C.04
DevID=8001649E.04
DevID=80016497.04
DevID=8001649A.04
DevID=8001649D.04
these data (from 0 to 7) are correct for the 8 tuners
or what else ?
DevID=80016498.04
DevID=8001649B.04
DevID=8001649C.04
DevID=8001649E.04
DevID=80016497.04
DevID=8001649A.04
DevID=8001649D.04
or what else ?
#8Yes, this is tuners id in ProgDVB settings.
About system log (even log) https://www.youtube.com/watch?v=J6vUOyxmU1o
need to find message with crash of ProgDVB.
ps: Most problem - for ProgDVB total not important 1 tuner or 10. I think some driver limit.
