upnp
olumalia
olumalia
Thu Sep 14, 2017 9:27 pm
upnp
#1 by olumalia
is it possible to connect to a server on my home network using progtv android ?
  • Thu Sep 14, 2017 9:31 pm
Re: upnp
What connection you like? Watch your home TV? You can try open port on firewall and connect by dynDNS for example.
  • Fri Sep 15, 2017 5:14 am
Re: upnp
#3 by Prog
Ops. ProgDVB not support upnp.
  • Fri Sep 15, 2017 5:45 am
olumalia
olumalia
Re: upnp
#4 by olumalia
Thanks for the speedy reply, no worries love the app :)
  • Fri Sep 15, 2017 6:58 am
olumalia
olumalia
Re: upnp
#5 by olumalia
what i did was install apache and my-sql and direct all my media to the www. folder and made a simple m3u
it works really well
  • Tue Sep 26, 2017 6:53 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 2:01 am
