Subtitle Question?
  • 1
  • 2
amsterdamxxx
amsterdamxxx
Tue Apr 04, 2017 10:30 am
Subtitle Question?
#1 by amsterdamxxx
does it have subtitle support?
I release 'm3u' list from the Enigma 2 Sat Receiver...but there is no option to refer to the subtitles
I'm sorry for bad English
  • Wed Sep 20, 2017 10:43 am
Re: Subtitle Question?
Yes, ProgTV support some types of subtitles. Check Options->Playback->Engine must be enabled.
Subtitles list in Menu of channel.
  • Wed Sep 20, 2017 2:28 pm
amsterdamxxx
amsterdamxxx
#3 by amsterdamxxx
I do everything you say,I can not find the subtitle option!!!
  • Thu Sep 21, 2017 12:59 pm
amsterdamxxx
amsterdamxxx
#4 by amsterdamxxx
I found Subtitle....but when I put Media Player on, then there's no option...!!!
when I put another Player, then the ad will not release the channel
View My Video
  • Thu Sep 21, 2017 1:59 pm
#5 by Prog
No can watch video. But check playback mode in Menu->Playback. Subtitles must be in all modes exclude MediaPlayer.
  • Thu Sep 21, 2017 3:33 pm
amsterdamxxx
amsterdamxxx
#6 by amsterdamxxx
There are subtitles for everything, except for Media Player
  • Thu Sep 21, 2017 7:27 pm
#7 by Prog
Yes. ProgTV request Engine for subtitles. Any more problems with subs?
  • Thu Sep 21, 2017 7:31 pm
amsterdamxxx
amsterdamxxx
#8 by amsterdamxxx
there is no option to play subtitles when I play over the 'Media Player'
  • Thu Sep 21, 2017 7:46 pm
#9 by Prog
Mediaplayer not support 2/3 of ProgTV functions include subs. If MediaPlayer best for you then can try MP+, but possible problems with sync.
  • Fri Sep 22, 2017 4:56 am
Madmax1
Madmax1
Sat Mar 31, 2018 11:43 am
#10 by Madmax1
Hi, I'm using the free version and I can't find a way to enable subtitles not in .m3u or vod.
Do I need the paid version?
Thanks
  • Sat Mar 31, 2018 11:52 am
#11 by Prog
Total same in all versions. What format of subs? Do you use Engine?
  • Sat Mar 31, 2018 1:30 pm
Madmax1
Madmax1
#12 by Madmax1
Closed caption on live tv and ssa subtitles for movies.
I tried all players, I have engine turn on but I get subtitles disabled.
I made a key to access subtitles, but always come disabled.
  • Sat Mar 31, 2018 1:43 pm
Madmax1
Madmax1
#13 by Madmax1
I'm using iptv and db over ip.
  • Sat Mar 31, 2018 1:45 pm
#14 by Prog
I am not test closed caption very long time. Can you share me link for test of subtitles?
  • Sat Mar 31, 2018 3:43 pm
Madmax1
Madmax1
#15 by Madmax1
I'm using a private iptv service. I seen videos of people using closed caption. There's a link above I this thread.
I already paid for the remove add, and didn't worked.
I tried movies too but same problem.
  • Sat Mar 31, 2018 4:23 pm
  • 1
  • 2
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 2:01 am
