Hi Prog,
The channel list in ProgDVB Client mode is wrong.
The channel name in the list is "A", but the channel in the screen(playing video) is "B".
OR
The channel in ASX file exist but not in list in ProgDVB(after channel update, of course).
The last good version for ProgDVB Client is 7.14.6.
Ex.: 7.21.1 for Server(home version) and 7.14.6 for client work very fine, but 7.21.1 for client have wrong channel list.
The server side is correct and I think this is only client side problem.
Both vresions x86 and x64 tested.
This is bug or I have very specific personnel problem?
Best Regards,
Momchil
Re: The channel list in ProgDVB Client mode is wrong
#2Why you not use same versions on client and server?
#3Yes, I tried - "7.21.1 for Server(home version) and 7.14.6 for client work very fine, but 7.21.1 for client have wrong channel list."
The answer is - Because after 7.14.6 the Client side is broken(channel list).
#4I am recomend use ~same version on client and server.
#5Hi Prog,
Where is "Nova TV" with last version of ProgDVB? Look the screenshots, please!
The Server side is 7.21.1x64 Home.
And NO, this is NOT a Sort channel problem.
This is not always but one on more channels missing or have wrong name.
#6Internet TV? My script test channels time to time and remove dead channels.
#7Internet TV?! No.
My TVs is from DVB-C tuner. The channel "Nova TV" is not dead.
The last good version is 7.14.6 for client side.
In your changelog : "27.07.2016 ProgDVB v7.15.0 Many fixes in network clients, ProgDemux, support of Mainconcept HEVC, ..."
#8Hm. Try remove all channels (Channel list->remove channels) and import again (Channel list->search-> source name)
#9The channel base of the server and of the client has been recreated. For now all is good, but my experience is very bad. I will write here if I have problems.
Thanks!
Edit:
30 minutes later...
OMG!
The name of the channel in the list is XXX but the real channel in the screen is YYY.
Look the screenshot. BNT World... BNT World... BNT World... BNT World... 4 times...
Cool! This is only one example.
Or sometimes 1-2 channels missing from the list...
I don't know that happening.
Please, check again the changes in version 7.15.0 for client side. For me the problem start from this version.
Thanks!
Edit:
30 minutes later...
OMG!
#10Please send me data files of ProgDVB from server side.
ps: I hope you use last ProgDVB on client and server side.
#11OK, you want the folder "ProgDVB" from "Program files" or specified files?
You can see the version - 7.21.1, this is the last version. I use this version on the server side and on the client side too.
#12Data folders. Channels, config,... You select this path in installation time.
#13But the problem isn't in the server because with 7.21.1 on server side and 7.14.6 on client side I can't see any problem.
#15OK
